4runner Still Shaking/Shimming down the road
Alright so i have a 99 4runner that still shakes down the road at speeds over 60mph. ive been trying to fix it for the last year and have replaced the shocks, sway bar links, Steering Rack Bushings, Tires. Also Ive had it check out by two different mechanics. The sway has gotten so bad that if it does it you will smack your head against the windows. I have noticed that it seems like its fine as long as you have pressure on the steering wheel (either moving it left our right slightly) it doesnt shake but if you just hold it still it goes crazy. Also their is quite of bit of play in the steering well probably 2-3" each way of center. Could the rack and pinion be shot? Or any other ideas?
You might want to try and put the front end up on jack stands and have someone hold the steering wheel while you grab each tire and try to turn in it and out on its steering axis and check for any slop.
Also you don't have anything noted in your signature, is your 4runner bone stock or lifted, ETC. Also is it mostly a street rig or you do much off roading ?
FOG
No real off-roading and about 140,000 miles at that point. I purchased a new Toyota rack for about $800...
Andreas
What happens when you take it in for alignment? what do the techs say? Tie rod inners okay? What about the outers? ball joints look good?
Off the top of my head- it does sound like your rack. Shop online they can be had for a lot less than $800, but that does sound about right for a stealership.
But confirm first before throwing more money at it. Truck is where? give more details as suggested in your signature so people can be of more help.
Every 4runner I've driven has always had VERY tight steering with ZERO play in the steering wheel. It sounds like something is worn in the rack and pinion unit which is very uncommon.
FOG
FOG
FWIW, I personally replaced the entire steering rack (hub to hub) on my 4Runner three years ago. Hell of a job and I only did it because the play was within the rack.
Andreas
Andreas
Tires are brand new. so my buddy had problems with his drive shaft and u joints and its not that knid of vibration but instead its more of a side to side motion like someone is shaking the car
I am a little amazed that no mention of steering rack bushings has been made. Lots of threads and a cheap DIY. Certainly worth checking before going internal on the rack. Just climb underneath and see if the rack moves as some one turns the wheel.
Ok when you say you replaced the steering rack hub to hub--Does that really mean everything connected to the hubs
Ball joints, Tie Rod ends...etc.....
I would also take it to a GOOD alignment guy--a proper alingment for our trucks should be about $200.
My suggestion--find a guy who races and ask him who sets up his suspension......It sounds like your front could be soooo off from the rear that it is causing it to "slip sideways" if that makes sense
AND when you get the alignment done get a 4wheel alignment to make sure all those angles are right!!!
Balance wheels with the proper adapter also--we are lug centric--not hub centric
there isnt--but it will help determine your thrust angle-----or uncover some other problem!!! Like blown lower or upper link bushings, bent frame, somebody setting up the front suspension like a 10lbs water head----etc....
What i am getting at here is look at the whole picture--if it is good then you can mark it off the list and move on
