front stub shaft removal with a locker in there
I'm trying to get the stub shaft off of my front IFS since the axle seal is leaking. I read somewhere that there is supposed to be a C clip holding the axle in there but for the life of me I can seem to see it because of the lockrite that's in there.
Do I have to pull the locker to get the stub shaft out? Please tell me no.
check this page out.
http://www.gearinstalls.com/ifs.htm
from zuks site .
just use a large screwdriver.
from zuks site .
from zuks site .
from zuks site .
Thanks!
FYI, you can often get those shafts out by using a block of wood and a BFH. Angle a length of 2x4 against the back side of the flange and smack it as best you can to unseat the spring clip holding the shaft in.
I did something similar. I used a dead fall hammer and after two hits it pulled out. So easy.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
Jul 9, 2015 02:34 PM
