Sponsored by: CARiD
4" ifs lift question
Old Feb 23, 2010 | 02:36 PM
Sammyboy's Avatar
when installing a front pro comp differential kit how does one make the the front drive shaft have a steep enough angle to connect with the fron differential?
Old Feb 23, 2010 | 03:09 PM
4x4runr's Avatar
what year?
It should be able to fit perfectly, at least it did for me 904runner....
Old Feb 23, 2010 | 03:16 PM
Sammyboy's Avatar
94 pickup extra cab and sr5 if that makes a difference
Old Feb 23, 2010 | 03:30 PM
Firefightertaco's Avatar
yeah it should be able to fit, is there anything stopping it from dropping down now and just bolting up to the diff
Old Feb 23, 2010 | 03:50 PM
iamsuperbleeder's Avatar
sway bar maybe?
don't they come with drop brackets for the sway bar mounts? have you installed those yet?
Old Feb 23, 2010 | 04:03 PM
Sammyboy's Avatar
no nothing blocking it just limits on the universale. i have the swaybar, and swaybar drop, but i havnt bolted it up yet
Old Feb 23, 2010 | 04:09 PM
4Crawler's Avatar
Might be your CV joint does not have enough angular travel:
- http://www.4x4wire.com/toyota/tech/cvmod/
Old Feb 23, 2010 | 04:43 PM
b4wheeler's Avatar
Check the scatter shield for the front driveshaft CV joint. It may be making contact.
I could not get mine to line up and took that off, then found the passenger side diff mount was not tight. After tightening this mount, the driveshaft bolted right up.
Old Feb 23, 2010 | 04:54 PM
Sammyboy's Avatar
i cut the sheilding, but it doesnt have the angle , its it doesnt have the angle i think i may need to mod
Old Feb 23, 2010 | 05:04 PM
Ardent's Avatar
I had to use a DS from a SA '84-85 rig. DS shop swapped the flanges for me (the bolt pattern is slightly different) and lengthened/shortened as needed. All in all I think the DS work and DS cost me around $150.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
