93 truck gear and drivetrain questions
I have a 93 pickup with a 3.4 and a five speed. I'm running 4.56 gears now with 31 inch tires. At 80 mph i run at 3400 rpm and to me this is just a touch to high. i plan on doing a sas with a 84 pickup axle and will use the 4" ifs eliminator kit. i have a trd e-locker that i plan on running in the setup and was wanting to use another e-locker in the front axle. my questions are...
1. will a e-locker work in the front with housing mods?
2. how will 4.88 handle 35x12.5 tires?
3. if i cant find a reasonably cheap e-locker where should i run the one i have?
if you have any other comments let me know thanks
x2
All of that has been done many hundreds of thousands of times with great success and has been documented many hundreds of thousands of times. You are in good company.
The build you are talking about is cookie cutter these days, so you will have tons of resources to draw from. You will be able to find many threads on each of those mods, and shouldn't have any issues.
Sounds like a really cool truck. Keep up the good work, and be sure to post pics when its done!!
GreenLion
Jun 7, 2021 10:49 AM
TheManOutside
Jun 18, 2015 03:32 PM
