PS Pump Squeaking?
Old Feb 16, 2010 | 08:52 AM
yotanut's Avatar
PS Pump Squeaking?
My PS Pump is leaking and has been leaking for at least 20k - 30k miles. I just keep adding fluid when it needs it. I have a squeak that sounds like it is coming from the PS pump especially when the vehicle is cold.
Is it possible that the PS pump can cause this squeak? I can't afford to get it replaced for a couple more months, can I just keep adding fluid when it needs it? Will the PS pump ultimately fail?
Thanks in advance.
Old Feb 17, 2010 | 09:01 PM
brian2sun's Avatar
If the pump is leaking, it'll probably die soon. Hard to say if it'll last a couple more months or not.
Old Feb 17, 2010 | 11:27 PM
hodgepodge79's Avatar
Just yesterday I rebuilt the P/S Pump on my '87. I ordered a seal kit from Oreilly's ($16) and it only took me three hours to remove, break down, build up, reinstall. Follow the instructions here:
http://personal.utulsa.edu/~nathan-b...11powerste.pdf
Easy.
Also, your alternator located directly beneath your leaking P/S pump will benefit from some attention to the leaks.
edit:I see it's a 3.4...good luck with that.
Old Feb 18, 2010 | 06:50 AM
Kerby J's Avatar
hodgepodge79 in the 3rd gens the altinator is on the oposite side of the engine from the ps pump i would say when u do replace it all youll have to worry about if you do it yourself is just bleeding the system
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
daddio
Aug 9, 2015 07:17 PM
TJWilly
Jul 31, 2015 02:05 PM
calderp
Jul 27, 2015 09:58 AM
Jonny246
Jul 24, 2015 12:37 PM
