Engine Cut Off after a hard stop!
I would also check the brake booster vacuum lines. On our subaru, I found no issues with a vacuum leak, but the problem seems to be a selanoid inside the transmission that's not going into neutral when coming to an abrupt stop.
Sounds like a wire shorting against something or your COR (circuit open relay) relay is not making good contact in the socket or is going bad. Those relays can be a problem since our trucks are getting old. Sounds like you are in for a bitch of a time finding that one.
If that doesn't fix it I would be looking to the AFM. It controls your fuel pump and air/fuel mixture. If you snap the throttle back, the door in the AFM is shutting and may be causing the fuel pump and COR relay to shut off.
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I have a new VAF.....so I don't think that's the problem....was a while ago though, that's why I replaced it
......bought the new one off ebay for $154.68 free shipping and life time warranty...if any one is interested here's the link http://cgi.ebay.com/ebaymotors/1994-...item48394ffd16
Do you have the old one? Can you borrow a FACTORY, OEM MAF?
Last edited by buckz6319; May 20, 2010 at 05:22 PM. Reason: added..(I replaced the old VAFM because it had a bad air sensor and was throwing a code not because it was cutting out the en
