can i use 95 4runner mc instead of an fj80 mc?
so im doing the mc and booster upgrade on my 85 4runner and i wasnt paying attention when i ordered parts.
i ordered the MC off of a 95 4runner instead of a 94 LC. my question is will it still work/ does it have the 1" bore that the LC MC has
I believe every V6 2nd gen 4runner had a 1" master, thats what I'm running on my 87.
From Pirate
"Brake Master Cylinder info
In addition to the Rotor swap, some people like to put bigger MCs in so that they have more fluid movement.
In this case, you want to acquire a Master Cylinder for a V6 truck or 4runner. It should be the 1" Bore. This is pretty much a bolt in replacement. Requiring you to move some brake lines slightly at worst."
http://www.pirate4x4.com/forum/showthread.php?t=251887
From Pirate
i finally got time to bleed them. first off i found out that whoever owned the truck before me never bled the lspv it was puking out what looked like oil so i gravity bled the whole system. secondly autumn (my truck) stops amazing now! first time i stopped i almost put my friend into the windshield
in addition to swapping the master cylinder, consider getting a dual diaprahm (sp?) booster
out of a turbo 86-87 or T100, probably a couple of other sources) but it would help that larger master cylinder reach its full potential
You can use a duel diasphragm brake booster from any 89-95 truck or 4Runner on our trucks, i have a duel diaphragm brake booster and master cylinder from a 92-93 4Runner on my 86 4Runner and it made a nice improvement to my braking.
I to have a booster and MC from a 92 4runner v6 on my 88 . I actually just installed it because it looked better than what was on my runner when i bought it .
I know the mc is a 1" , but how do you know if the booster is a dual diaphram booster?
The duel diaphragm booster will be alot wider front to back then the small thin one used on 84-88 trucks and 4Runners.
hey i have a question i have a 82 Toyota pickup come into my work and it has a break problem some on put a fj axle under the front of it to have vented rotors and now it wont stop i think it cause the MC is to small so i was wondering what i should put on it
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
