can i use 95 4runner mc instead of an fj80 mc?
Old Feb 14, 2010 | 09:53 AM
laskt9's Avatar
so im doing the mc and booster upgrade on my 85 4runner and i wasnt paying attention when i ordered parts. i ordered the MC off of a 95 4runner instead of a 94 LC. my question is will it still work/ does it have the 1" bore that the LC MC has
Old Feb 14, 2010 | 02:22 PM
ccannon222's Avatar
95 4runners came with 1" bore MC. Two styles, ABS and non-ABS. Are you running disk or drum brakes in the rear?
chris
Old Feb 14, 2010 | 03:02 PM
laskt9's Avatar
im running drums
Old Feb 14, 2010 | 03:37 PM
4banginRunner's Avatar
I believe every V6 2nd gen 4runner had a 1" master, thats what I'm running on my 87.
From Pirate
"Brake Master Cylinder info
In addition to the Rotor swap, some people like to put bigger MCs in so that they have more fluid movement.
In this case, you want to acquire a Master Cylinder for a V6 truck or 4runner. It should be the 1" Bore. This is pretty much a bolt in replacement. Requiring you to move some brake lines slightly at worst."
http://www.pirate4x4.com/forum/showthread.php?t=251887
Old Feb 14, 2010 | 03:51 PM
laskt9's Avatar
awesome thank you! i guess i didnt mess up too bad then
Old Feb 14, 2010 | 06:37 PM
myyota's Avatar
I have a brake booster and master cylinder off of a 92 or 93 4Runner on my 86 4Runner, and it works good and was a nice improvement over the stock set up.
Old Feb 14, 2010 | 06:51 PM
laskt9's Avatar
do you have drums or discs in the rear?
Old Feb 14, 2010 | 09:51 PM
myyota's Avatar
Stock drums in the rear and stock discs up front, but i plan on upgrading to vented rotors and V6 calipers in the front in the near future.
Old Feb 20, 2010 | 05:43 PM
laskt9's Avatar
so just letting people know. it installs fine i just have to bleed the brakes tomorrow to see if my braking has improved
Old Feb 27, 2010 | 11:54 AM
laskt9's Avatar
i finally got time to bleed them. first off i found out that whoever owned the truck before me never bled the lspv it was puking out what looked like oil so i gravity bled the whole system. secondly autumn (my truck) stops amazing now! first time i stopped i almost put my friend into the windshield
Old Feb 27, 2010 | 12:01 PM
dropzone's Avatar
Fossilized
in addition to swapping the master cylinder, consider getting a dual diaprahm (sp?) booster
out of a turbo 86-87 or T100, probably a couple of other sources) but it would help that larger master cylinder reach its full potential
Old Feb 27, 2010 | 12:20 PM
myyota's Avatar
You can use a duel diasphragm brake booster from any 89-95 truck or 4Runner on our trucks, i have a duel diaphragm brake booster and master cylinder from a 92-93 4Runner on my 86 4Runner and it made a nice improvement to my braking.
Old Feb 27, 2010 | 12:29 PM
RMA's Avatar
RMA
I to have a booster and MC from a 92 4runner v6 on my 88 . I actually just installed it because it looked better than what was on my runner when i bought it .
I know the mc is a 1" , but how do you know if the booster is a dual diaphram booster?
Old Feb 27, 2010 | 12:40 PM
laskt9's Avatar
the booster will be longer/stick out farther. and i have one from a 95 4runner on my truck
Old Feb 27, 2010 | 12:43 PM
myyota's Avatar
The duel diaphragm booster will be alot wider front to back then the small thin one used on 84-88 trucks and 4Runners.
Old Jul 25, 2011 | 12:10 PM
Evanevans's Avatar
hey i have a question i have a 82 Toyota pickup come into my work and it has a break problem some on put a fj axle under the front of it to have vented rotors and now it wont stop i think it cause the MC is to small so i was wondering what i should put on it
Old Jul 25, 2011 | 12:47 PM
Etype R's Avatar
For the booster, get one out of a 90-95 2wd truck that has a dual diaphram booster. They are the smaller size like the turbos had.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
