replacing rotors
Old Sep 23, 2002 | 07:44 PM
data's Avatar
Senior Member
replacing rotors
Well the time has come to replace these ole warped rotors with some fresh new ones. I was just wondering if anyone has a write-up on how to change rotors on a 3rd Gen. How difficult is the process?
Old Oct 7, 2002 | 10:20 AM
data's Avatar
Senior Member
Old Oct 8, 2002 | 05:45 PM
WATRD's Avatar
Re: replacing rotors
There isn't much to write up. Remove the wheel, remove the two bolts holding the caliper on, remove the retaining, Phillips screw if so equipped, remove the rotor.
Installation is the reverse.
If you have an impact wrench for removing the lug nuts, the whole thing will take you less than ten minutes a wheel.
Old Oct 10, 2002 | 04:25 PM
data's Avatar
Senior Member
wow! doesn't sound tough at all!
Old Oct 10, 2002 | 05:21 PM
WATRD's Avatar
It's really not a big deal. A couple of caveat's come to mind 'though...
[list=1][*]Do not allow the caliper to hang from the brake line.[*]When the calipers are off, do not, under any circumstances step on the brake pedal... it will over extend the slave cylinders.[*]If the caliper doesn't want to fit back over the new rotor and you need to push the pistons back a bit, Push BOTH sides at the same time.[/list=1]
That should do you... but all in all it's a no brainer.
Best of luck!
Old Oct 10, 2002 | 10:10 PM
data's Avatar
Senior Member
I LOVE your truck!!!!!!
Old Oct 10, 2002 | 11:27 PM
WATRD's Avatar
Thanks! I was looking yours over in the people picture thread and it's no slouch either Too bad you are so far away, it would be fun to wheel them on the same trail.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
msane99
Jul 11, 2015 08:08 PM
smiley52
Jul 11, 2015 05:16 AM
