93-98 T100s All T100 trucks
T100 lazy seat belts
Old Feb 11, 2010 | 09:57 AM
dannie's Avatar
I know every T100 (and other Toyota's for that matter) have this lazy seat belt return spring. Any body got a reliable fix for this. I have read advise on the internet about pulling off the side panel and winding the spring tighter, but wasn't to confident with some of the procedures I read. Anyone have a better fix?
Old Feb 11, 2010 | 10:17 AM
tj884Rdlx's Avatar
i've never heard of winding the spring tighter, but cleaning them makes a big difference. Hair and other crud gets in the windings. I've used a lighter to burn out knots of hair on spindles. Just be careful around synthetic fibers; don't overdo it.
a quick google search for cleaning seat belts should give you some more info.
i've found that cleaning the belt itself with a Mr. Clean Magic Eraser is an awesome technique for this and many other little things...and it only uses water. For heavy crud or grease, brake cleaner is one of my favorites.
Old Feb 11, 2010 | 12:00 PM
4Crawler's Avatar
http://www.4x4wire.com/toyota/minutemods/seatbelt/
I did the above plus cleaned the belt. Stretched it out on the porch, sprayed down with upholstery cleaner, worked that in with a brush and rinsed with a hose. FLipped belt and cleaned the other side and left to dry in the sun. Then sprayed the belt with some Scotchgard to help keep it clean and the silicone helps to lubricate the belt as it retracts. Has worked fine for years now.
Old Feb 11, 2010 | 12:02 PM
MaK92-4RnR's Avatar
theres an easy way to solve this... when you take your seat belt off... lean forward and throw it behind your back as your getting out of your truck... works everytime. I come back out to the truck and its full retracted
Old Feb 18, 2010 | 06:15 AM
dannie's Avatar
involved fix
This is the fix I was talking about that I had seen on the internet.
Old Feb 18, 2010 | 08:25 AM
BamZipPow's Avatar
This is what I did fer my seat belts...
Old Feb 18, 2010 | 08:39 AM
Teuf's Avatar
BUT, I don't wanna fix my return spring.
Old Feb 22, 2010 | 08:14 AM
Zuke79's Avatar
So much WIN!
he's gone
7
Dec 3, 2019 07:08 AM
markwink
Aug 18, 2015 12:38 PM
83Toyota88
Aug 18, 2015 07:42 AM
TDonkey
Jul 26, 2015 10:14 AM
