Whos got a Timing belt and water pump replacement write up?
The shop wants to do it for $750, but i want to save some money and try to do it on my own. but I cant find a good write up.. lots of pictures are good.. im a visual person haha thanks for the help guys
its for my 98 4runner 5VZFE
Just find the factory service manual for your vehicle. It will have everything you need, including pictures, step-by-step instructions, and torque specs for the bolts.
BTW: $750 is an ok deal for a timing belt and water pump job, as long as they were going to usa all Toyota OEM parts.
Looks like you'll find the FSM you need in here: https://www.yotatech.com/forums/f128...-years-156128/
http://www.4x4wire.com/toyota/maintenance/timing_belt/
The big suck factor is the crankshaft pulley, off and off!
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
easily overlooked items needed:
crank pulley holder (you can make one) and; tensioner tool and;
HUGE 75-250ft/lb Torque Wrench (can be rented)
I did it myself because I'm a big believer in if I did it, I know it was done right (even if I'm learning along the way!)
pm if you have questions. i did it in a day... i had a thread around here somewhere on it.
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
infinityisfive
Jun 16, 2015 06:51 PM
