Whos got a Timing belt and water pump replacement write up?
Old Feb 11, 2010 | 07:37 AM
dgl4runner's Avatar
The shop wants to do it for $750, but i want to save some money and try to do it on my own. but I cant find a good write up.. lots of pictures are good.. im a visual person haha thanks for the help guys
its for my 98 4runner 5VZFE
Old Feb 11, 2010 | 07:45 AM
mastacox's Avatar
Just find the factory service manual for your vehicle. It will have everything you need, including pictures, step-by-step instructions, and torque specs for the bolts.
BTW: $750 is an ok deal for a timing belt and water pump job, as long as they were going to usa all Toyota OEM parts.
Old Feb 11, 2010 | 07:48 AM
mastacox's Avatar
Looks like you'll find the FSM you need in here: https://www.yotatech.com/forums/f128...-years-156128/
Old Feb 11, 2010 | 07:56 AM
Gerdo's Avatar
http://www.4x4wire.com/toyota/maintenance/timing_belt/
The big suck factor is the crankshaft pulley, off and off!
Old Feb 11, 2010 | 09:31 AM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
easily overlooked items needed:
crank pulley holder (you can make one) and; tensioner tool and;
HUGE 75-250ft/lb Torque Wrench (can be rented)
I did it myself because I'm a big believer in if I did it, I know it was done right (even if I'm learning along the way!)
pm if you have questions. i did it in a day... i had a thread around here somewhere on it.
Old Feb 12, 2010 | 10:27 AM
dgl4runner's Avatar
thanks guys, this will save me a ton of money!
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
paxanders
Jun 21, 2015 06:29 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
infinityisfive
Jun 16, 2015 06:51 PM
