Sponsored by: CARiD
sas?
Old Feb 4, 2010 | 12:25 PM
just call me smithy's Avatar
sas?
I had a question aboy sas......could you use a Suzuki frunt axle for a swap? there was one at the junk yard and it looked pritty good. thank you for your time and help.
Attached Thumbnails sas?-suzuki-brif-2.jpg   sas?-suzuki-sas-2.jpg   sas?-suzuki-pinion-2.jpg
Old Feb 4, 2010 | 12:26 PM
one more
Old Feb 4, 2010 | 12:28 PM
DeathCougar's Avatar
Sure, you could use it no problem.
In fact, those will even be easy to get parts for since most Suzuki owners swap their axles out for Toyota axles (something about bigger, stronger, less breakage?) so there should be a ton of suzuki parts available.
Old Feb 4, 2010 | 12:34 PM
thanks.......i do plan on befing it up...but how would i be able to tell about the gear ratio in them?...would they mach toyota ratios?
Old Feb 4, 2010 | 12:38 PM
BigBluePile's Avatar
You'd have to google it or find a 'zuki site to ask that. Junkyard mathmatics say that if you spin the ONE side twice and count the pinion turns and then divide will give you a ball park ratio.
again...theres a reason why 'zuki guys swap for Yota axles...
Old Feb 4, 2010 | 12:42 PM
ok thank you.......are the zuki axles weak?
Old Feb 4, 2010 | 01:24 PM
waskillywabbit's Avatar
You are going backwards. Search.
Old Feb 4, 2010 | 02:41 PM
backwards? so this wouldent be a good swap? it looks stronger then my ifs.....it has brifs......not that im doughting the help i would just like to learn thank you for your time and help
Old Feb 4, 2010 | 02:57 PM
abeD85flatbed's Avatar
the suzuki axle is a pile. If you want cheap find a dana 44 from a wagoneer or cherokee chief. they are narrower than a fulsize axle. Generally the six lug versions had the driver side input and the five lug versions had the passenger. I believe you can swap the steering knuckles though and wind up with a six lug passenger side input. Don't waste your time with the suzuki axle.
Old Feb 4, 2010 | 03:28 PM
4banginRunner's Avatar
Dont waste your time and money going backwards with the Zuk front...go Toy axle
Sami guys swap OUT zuk axles for Toy axles.....
Old Feb 4, 2010 | 03:29 PM
camo31_10.50's Avatar
there's a chief sittin in a field by my house 6lug though lol so it'd probably be driverside drop
off topic: would the wheels off of a six lug jeep fit on my toyota? idk what the bolt pattern is on em (other than six lug)
Old Feb 4, 2010 | 03:43 PM
Center hole is probably too small
Old Feb 4, 2010 | 04:00 PM
yoder519's Avatar
i was thinkin the sami axles are quite a bit narrower than toyotas. what are the sami axles like a dana 20
Old Feb 4, 2010 | 04:19 PM
ugh double post...
Last edited by BigBluePile; Feb 4, 2010 at 04:21 PM. Reason: stupid slow computer...
Old Feb 4, 2010 | 04:21 PM
Hey 4bangin!!! Nice sig!!! lol!!!
dang I think that thread got locked out too!!!
Old Feb 4, 2010 | 05:10 PM
well i had taken mesurements and langth wise the axle would fit.......
other then beeing weaker what specific areas are problematic for that axle.....they are giving me a deal that i cant resist.
Old Feb 4, 2010 | 05:12 PM
You are wasting your time, your money if you put a zuk axle under your Toyota...period.
Old Feb 4, 2010 | 05:14 PM
mastacox's Avatar
Just because it's cheap doesn't mean its a deal. You're not listening to any of the other posters! You don't want that axle for a swap, you're better off staying IFS!
Old Feb 4, 2010 | 05:21 PM
ok iam listening........... i saw just wanting to know ......i truly value wiser knowlage and will continue to look for a solid axle that will soot my college budjet...... "Just because it's cheap doesn't mean its a deal." ya it was to good to be true......
Yes you can resist....SAY NO.
