I need help! im redoing front suspension parts
I need help, i have to replace both front lower control arms, all tie rod ends, idler arm, pitman arm and all balls joints. When im doing this do i need to adjust the torsion bar? What certain things will i have to take off to do this? What do i need to adjust and do a certain way.
I'll be the first to say it. SAS! You're already tearing every thing up. If you don't go that route when replacing all the front end components obviously you'll need an allignment. Your truck is going to sit a little differently after all the suspension work so when you're done measure to see if you'll need the torsions adjusted. P.S. why you doing all of this? I'll bet there's a good story behind it all. It's either that or some hack mechanic tried to tell you that your front end is out of whack and the whole thing needs to be replaced. He will then shortly after telling you this offer to buy your truck to just get it off your hands. Just kidding happened to me a few years back when i was a bit of a novice. Pickle forks and a puller is your friend.
Well my lower control arms snapped from rust ( no surprise) and when it did it bent other parts with it and the ball joints just need replaced because there worn. Also id do it SAS if i had the money to do it
so far youve already got a good plan just be careful when takin off the lower control arms off i had to cut mine off and i dont live in the rust belt. and for the ball joints of course you will need a pickle fork to get them off
I re-read the OP and if you're not affecting the upper control arm, jacking the truck off the ground will put the UCA on the bump stop and you won't have to do anything to the t-bars.
/me hides
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
