2000 4unner - Brittle Trans Solenoid Connectors
Old Jan 21, 2010 | 01:20 PM
Abielecki's Avatar
Hi,
Can anyone tell me how to replace the trans solenoid wire harness? I see that it plugs into the valve body but don't know if the valve body needs to be dropped or the harness just yanks out.
I am rplacing the "E" solenoid and the locking tab snapped off the connector, extremely brittle.
Pic's attached of the solenoid wire harness as it plugs into the valve body.
Thanks in advance
Attached Thumbnails 2000 4unner - Brittle Trans Solenoid Connectors-img00487.jpg   2000 4unner - Brittle Trans Solenoid Connectors-img00486.jpg
Old Jan 21, 2010 | 03:35 PM
mt_goat's Avatar
Bummer, I don't know how deep you'd have to go to replace the whole harness. Maybe you could cut the harness and solder on a new connector or maybe you could somehow secure the connector together without the locking tab.
Old Jan 21, 2010 | 03:47 PM
Abielecki's Avatar
Hi - Thanks for your reply. I was able to order the harness for $20 from Toyota, I'll see what the main connector looks like, maybe that'll give me a clue on how to disconnect/connect. Worst case I'll cut and solder on the new solenoid connector end as you suggest. Also heard someone crimped the female end to get a tight fit without the locking tab being in place.
chuckross1957
Jun 28, 2019 10:19 PM
crammit442
7
Nov 29, 2017 12:30 PM
Gio8
Aug 27, 2015 12:14 PM
msged2007
Aug 22, 2015 07:46 PM
Jnkml
Jul 6, 2015 01:20 PM
