pic request - electrical connector
Finally am able to pull out the aftermarket senders/gauges that the PO installed, but I feel he may have clipped off the wires/connector from the harness.
I need to know the color of wire and/or connector that attaches to the following...
-Oil pressure sensor (for gauge if it matters)
-Engine temp sensor (for coolant, located centrally on intake manifold)
The OE senders both have male spade connectors, so I'm assuming the connectors on the harness side will be female spade, but there are no extra wires around, just the old aftermarket lead wires, and these don't go to the factory gauge...
thanks!
-Chris
thanks!
-Chris
Hopefully you already figured it out, since its been 12 days and no one bothered to pull out a repair manual or look at their truck (I mean, really people, it took me all of 1 minute to look).
Coolant temp sender: yellow w/green stripe (the sensor on top of the lower intake manifold, near the center, right?)
Oil P sender: yellow w/blue stripe
Hopefully the wires aren't too dirty, as they will look almost the same
