Clutch sticking to the floor?
I have a 88 4x4 efi v6 3.ol, and the other day my clutch just went out and was sticking to the floor, my dad looked at it and saw some liquid like oil or something on the steel hose that runs from the master cylinder to the rubber hose that then connects to another steel line which then goes into my transmission. I took the hoses off today and one is dry rotted and i cant get that one fixed til friday, but i was wondering if i could bypass the rubber hose and just use a coupler from the steel hose from the cylinder to the other steel hose to the transmisson? can i bypass it?
if the rubber hose is leaking, you can swap it for another hose, but it should be rubber. if it is solid, the engine and body moves differently from each other and can break the line, reason for using flexible hoses
no mine sounds like a suction cup when i push it in.. and then i either have to pull it up with my foot or hand. then it pops back into place. its weird. i dont have the money to take it to the toyota guy over here in my hometown becuz he charges alot. becuz its hunting season everyones yotas are either breaking or he is doin tune ups for em.
The pedal should never stick to the floor cause there is a spring that pulls it back when you take your foot of it.... that spring is gone or broke. The rubber line needs to be replaced theres no messing around with "BS" rigging just replace it bleed system and be on your way.
if your leaking clutch fluid (brake fluid) than your probably low on fluid. if you top it off, it should hold off for a few days till and leaks below the low mark. for now you can top it off, bleed it and see how it goes. if it is leaking really bad, than its best to just replace what is leaking
ok so i looked today and the spring is there. but there is a rubber spacer goin through my firewall and a rob that ties into clutch pedal and it goes out of this hole. what is this/ it looks as if it is getting stuck in there could that cause the sticking of the pedal?
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
AGHHH!!
