5VZ 3.4L AC idler pulley
I'm looking for the bearing number for the AC idler pulley.
If you've replaced yours and have your old one laying around, or if you have replaced the bearing in yours, please, I'd love to know the bearing number for it.... thanks.
Heard a squeek on start up yesterday, timing belt, water pump and all accessory belts new.....just thought it was the most likely culprit.
New does not mean tight, however. I swapped all mine when I did the TB this spring, and I thought I had them good and tight. My alt belt needed some more turns after a few weeks to cure a squeak. Don't assume your belts are tight until you check. They should all be checked after running-in after replacement. (not TB, of course)
Rebuild procedure here...
http://www.ttora.com/forum/showthread.php?t=138131
There are apparently two different options.
One is OEM and the other is dealer option A/C. Sorry, don't know which is which.
The above procedure should be similar for both.
6203LU =
12mm thick
17mm bore
40mm outside diameter
6301-2RS=
12mm thick
12mm bore
37mm outside diameter
6203LU =
12mm thick
17mm bore
6301-2RS=
12mm thick
12mm bore
Hmm thats odd, I THINK this is the pulley i got from advance auto. AC is factory, this is a 99 limited. Those numbers are off the same pulley. Mine doesn't look like the one in that link. bearing pressed in, no snap ring. same as the one i took off the truck
Tell ya what, ill send it to you for the cost of shipping if you want, it was on the truck about a month or two until I got the whole tensioner system from toyota due to me breaking part of it being dumb.
LCE_Performance
Oct 1, 2015 01:03 PM
