Tundra BIg Brakes on 96 4runner
Old Jan 2, 2010 | 11:37 PM
sdsurfer's Avatar
i finally did it. It feels way better, no wobble, no fade and very responsive.
I did have the 231 mm calipers and pads with 2002 4runner alloys.
Old Jan 3, 2010 | 12:43 AM
85yota4x4's Avatar
how do you do this? do you just need tundra calipers and rotors?
Old Jan 3, 2010 | 06:18 AM
team_gforce's Avatar
yes, this is pretty much just a straight bolt in upgrade, depending on the type of wheels you have some may need spacers or you may have to grind a small amount off the back of the wheels to clear the calipers.
Old Jan 3, 2010 | 06:21 AM
sdsurfer's Avatar
ebay 100 bucks for drilled slotted rotors and pads. junkyard for tundra fresh pulled calipers
100 bucks and 150 for install. a few other mods just google it and youll see all the threads...
Old Jan 3, 2010 | 06:36 AM
BajaRunner's Avatar
Schweet!
Old Jan 3, 2010 | 09:35 AM
Tfry1's Avatar
I can't wait to get mine done it is definately on my list of mods. Truck looks good
Old Jan 3, 2010 | 12:02 PM
ChildrenOfBodom's Avatar
I had the same rims you have but I just changed to 17" Tundra rims... anyone know if these will fit that rim without spacers?
Old Jan 3, 2010 | 12:33 PM
Matt16's Avatar
How do you adjust the rears so that they brake proportionally harder as well? Can I assume the 3rd gens have an LSPV like previous 4Runners? If the front brakes are doing all the work, the truck pitches forward harder when brakes.
Old Jan 3, 2010 | 05:58 PM
sdsurfer's Avatar
i didn't. its just bolt in. 17 inch rims? NO PROBLEM. Some 16" rims have been reported to rub. But I have 2002 runner rims. You hVE TO also grind or bend back a portion of the dust covers. (they rub)
Old Jan 3, 2010 | 06:22 PM
Red3.slow's Avatar
You also have the option of doing the smaller tundra break upgrade which is 199mm as opposed to 231mm
only difference is the calipers, 199mm has the SWE13 stamping
I chose to do the 199mm upgrade seeing as I have the 16 inch split 3 spoke wheels.
Old Jan 3, 2010 | 08:55 PM
okie81's Avatar
Those slotted rotors look purdy, and your trim on the dust shield looks good too, nice work.
I did the 199mm upgrade as well and am still waiting to hear testimony from someone who has been behind the wheel of both upgrades for comparison
Old Jan 5, 2010 | 08:06 PM
85yota4x4's Avatar
will these clear 15x8 cragar soft 8's with 4" of backspace
Old Jan 6, 2010 | 04:38 AM
habanero's Avatar
They won't clear 15's at all.
Old Jan 6, 2010 | 06:35 AM
MaK92-4RnR's Avatar
if i remember right, this is only a bolt on for 3rd gen 4runners? what is needed to get these to fit on a 2nd gen?
Old Jan 6, 2010 | 09:26 AM
habanero's Avatar
https://www.yotatech.com/forums/f116...runner-193458/
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
ptb12
Jul 5, 2015 01:49 PM
