54mm nut and that big socket
Old Dec 18, 2009 | 03:59 PM
AustinTaco's Avatar
I am in the middle of working on my front axle and I wanted to throw this out there for anyone else that is attempting to work on the their axle and is contemplating buying the socket....But it!
I thought I could find one locally. Sears carries one online, but not in their stores. After searching everywhere, I did find a 55mm that was labled as being for use on Toyota RN, LN, and FJ's, which is also what the OTC brand says about their 54mm, so I bought it. Nope, its too big, so I ended up settling for a 2 1/8" socket. It is doing the job, but the problem I am running in to is that the last person to work on the front used the "chizzel my dizzel" method and tapped it out with a hammer and chisel. That works, but it leaves burrs on the edge of the nut that make the socket either a tight fit or not fit. Toyota only had two new 54 mm nuts, so I am using them and the best two of the old ones and sanding the edge down.
Hope this helps the next person.
Old Dec 18, 2009 | 08:18 PM
Etype R's Avatar
I have both a 2 1/8 socket and a trailgear 54mm socket. Both get the job done.
Old Dec 18, 2009 | 09:29 PM
MuddfreaksOffroad's Avatar
you dont even need a socket my buddy just did the front breaks on his 85 and its finger tight but if you do need something use a monkey wrench a big one lol but yeah they make a 54 mm socket just have to get it lol
Old Dec 18, 2009 | 09:32 PM
85excab's Avatar
mabey a monkey wrench fits on the 2wd's, but not on the 4wd's its recessed.
checkers and autozone both carry the 54mm socket for $15, worth every penny
if i ever see someone using a hammer and chisel again, imma gonna use the hammer on thier skull, retards...
Old Dec 18, 2009 | 09:39 PM
AustinTaco's Avatar
I went to Autozone, Oreilly's, Advanced, Sears, Napa, Main Line, and A-1, and none of them had a 54mm so I settled for the 2 1/8. It fits, but the old 54mm nuts that were chiseled made for a tight fit.
When I run into issues, I like to post up for the next guy.
Old Dec 18, 2009 | 10:11 PM
well i mean some kinda wrench cuz my friend did it with out a socket! lol so it can be done!
Old Dec 18, 2009 | 10:29 PM
BigBluePile's Avatar
I used 2.5" exhaust tubing...and it was free.
Old Dec 18, 2009 | 11:54 PM
DeathCougar's Avatar
Haha sig line material
Old Dec 19, 2009 | 05:33 AM
Etype R's Avatar
I had to use a impact gun to remove my outer lock nuts.
Old Dec 19, 2009 | 11:29 AM
hmmm really? were your bearings SHOT?
Old Dec 19, 2009 | 11:39 AM
Did you bend the tabs on the lock washer first? And you do know there are TWO nuts....don't you?
Old Dec 19, 2009 | 03:33 PM
4banginRunner's Avatar
TG sells brand new nuts, star washer and the index washer for $8.50 a side..
http://www.trail-gear.com/images/nut-kit-600.jpg
http://www.trail-gear.com/knuckle-service.html
Old Dec 19, 2009 | 03:48 PM
Etype R's Avatar
I know they should not require a torque wrench, I wasn't the one that last tightened them down The nut behind the lock tab washer was loose, and was turning off while I bent the tabs back for the washer. But even with the nuts being installed so tight, they were not gouged up. I also installed new wheel bearings when I tore into my front end.
Old Dec 19, 2009 | 05:55 PM
waskillywabbit's Avatar
If you are going to work on your Toyota, don't do it half ass with a hammer and chisel, buy the right tools for the job the first time and do it right.
Finger tight on 54mm spindle nuts...FAIL.
Old Jan 14, 2010 | 09:59 PM
JShaffer0525's Avatar
wabfab=win!
got my manual hub conversion kit and the 54mm socket from him.
Old Jan 14, 2010 | 10:45 PM
peow130's Avatar
Finger tight spindle nuts.
Have fun when your hub comes off going down the highway..
Old Jan 15, 2010 | 03:44 AM
Originally Posted by JShaffer0525
wabfab=win!
Old Jan 18, 2010 | 09:01 AM
jonzen1977's Avatar
Did you smash it into a hex, or beat it onto the nuts or what?
I need to do mine, just wondering how well this will work for others, before I order a socket.
Thanks
Old Jan 18, 2010 | 09:09 AM
Thanks
I used my small sledge and massaged the round tubing into a hex checking the fit with the hex washer(and NO I didn't beat it onto the washer while it was on the rig still). Once I had the fit down, I cut a tab at the other end of the tubing and folded it over and using a hose clamp secured it to the side. Cut and filed a nice 1/2" square for a wrachet and viola!! Now that I have a welder, I'll weld the tab down.
Old Mar 21, 2015 | 02:17 PM
Jleritz22's Avatar
54mm socket
Here are some photos of a home made one using 2.5"exhaust tube and welded on large washer and spare 1/2" drive socket. Sorry I haven't figured out how to upload photos here yet. Anyone?
