T100 Oil pan Question
Old Dec 16, 2009 | 03:27 PM
Ahbustae86's Avatar
I am swaping a 3.4 into my 91 4runner that has a SAS and 7 inches of lift. Do I still need the T100 oil pan if I have a lift kit? Will everything clear?
Old Dec 16, 2009 | 03:41 PM
DeathCougar's Avatar
If it has been SAS'd, you need a 2WD T100 pan, so the axle will clear. Without it, the axle will hit the pan and crush it.
Old Dec 16, 2009 | 04:25 PM
thefatkid's Avatar
What pan are you using on your 3.0? If that clears then it will clear when you install it on your 3.4l.
Old Dec 16, 2009 | 05:13 PM
dntsdad's Avatar
Essentially the same physical block so.......what Fatkid said.
Old Dec 16, 2009 | 05:48 PM
Not if you have a SFA it doesn't. If you have a SAS or a SFA, you need the T100 2WD oil pan.
The regular 3.0L pan is only for IFS applications.
Old Dec 16, 2009 | 10:14 PM
Ahbustae86's Avatar
So it won't clear even with the lift?
Old Dec 16, 2009 | 11:18 PM
If you take the truck offroad, no.
Old Dec 17, 2009 | 04:52 PM
thefatkid's Avatar
If he built his SFA with bump stop clearance for the 3.0 pan then it will work on the 3.4l. So your current SFA 4runner has a 3.0 and it clears with the stock pan, take your 3.0 pan and put it on the 3.4l. With 7" springs it should have about 5" to the oil pan before contact.
Now if he is just building everything at once including the SFA then use the T100 pan. You gain an extra 2-3" of up travel with that pan. You can put your 4runner at a more trail worthy 4" height, 7" is kinda big.
Old Dec 19, 2009 | 08:11 PM
Ahbustae86's Avatar
thanks guys for the info. I'm gonna just pay the little extra for the T100 oil pan.
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
