Transmission Maintenance
Old Dec 2, 2009 | 07:29 AM
truword1's Avatar
Question for you guys,
When changing the automatic transmission oil on a 1996 4Runner is it required to replace the filter? I've read some where that it is not required to place. Does it ever need to be replaced at some time?
Thanks
JD
Old Dec 2, 2009 | 07:35 AM
Kerby J's Avatar
no you dont need to it is listed by toyota to be a lifetime filter because when replaced you have to replace the whole unit it does not come apart
Old Dec 2, 2009 | 07:42 AM
mt_goat's Avatar
If you have the pan off anyway, I'd change it. You can get a new OEM one for $30-40 online. Not a bad idea to at least clean the magnets in the bottom of the pan every 100,000 miles or sooner.
Old Dec 4, 2009 | 10:51 PM
96743runner's Avatar
Replacing the filter is not required but I had mines changed anyway. It was actually pretty dirty and I figured that I'd might as well since I had it opened up anyways.
Old Dec 5, 2009 | 05:50 PM
yotaman101's Avatar
just replace the fliud and you'll be fine, no need to replace the filter
Old Dec 5, 2009 | 08:24 PM
brian2sun's Avatar
If you don't replace the filter at least inspect it and clean it. Blast it with some brake cleaner from the top downwards, then flip it around and blast it from the bottom. And let it dry before reinstalling.
If you really want to get down, I recommend this:
http://home.centurytel.net/stevenjac...sh/tranny.html
Hugh_Mann
Sep 16, 2015 03:59 AM
fabing455
Sep 7, 2015 08:08 AM
Jwp1
Sep 6, 2015 11:03 AM
kelly1450
Sep 2, 2015 12:29 PM
