80 4x4 Mystery Clunk in drive train
80 4x4 Mystery Clunk in drive train SOLVED
80 4x4 Mystery Clunk in drive train SOLVED bad ring and pinion « on: Yesterday at 04:53:01 PM »
Quote
Modify
Remove The previous owner put in a new engine (22r) and a new clutch and pressure plate. The tranny is original l-43. When I let out the clutch to quickly I get a clunk but it does not feel like the transmission is hitting the floor or anything like that. It feels like a really bad u joint.. He said it was alway there and he thought it was the tranny mount. When I lay under the truck and watch while someone lets the clutch out quickly I can see no movement of the transmission. The u joints are all tight. If I drive down the road and let up on the throttle ...then back down quickly... it clunks. It feels like a lot of slop somewhere. My tranny guy does not see how it could be in the tranny or t-case. He thinks mabey in the clutch assembly somewhere. We are getting ready to put in and L52 and I want to have every thing I need before hand. I hate to spend 100 bucks on a tranny mount if it is not needed. Any one got any ideas on where this slop could be hiding.
Thanks is advance again
Mark
My driveline has some play when I lay under the truck I can rotate it back and forth a fair amount.. If you were to put a mark on the rear end the play would be 3/8 to1/2 inch
motor mounts are tight
my rear diff pinion bearing is going out and causing my truck to clunk when i shift. it did it on a 2wd i had about a year ago you would be amazed how mutch the pinion moves when the bearing dosent keep it in place
The loose driveline slop was ring and pinion out of tolerence. 20 thousands.. Rebuild third member with old ring and pinion which were in great shape but put in a bearing kit and slop is gone. Mystery clunk is still there and is Axel Wrap...due to lift blocks.... New 5 speed is GREAT
Sep 4, 2015 09:27 AM
