Pre 84 Trucks 1st gen pickups
80 4x4 Mystery Clunk in drive train
Old 11-18-2009, 06:51 AM
69800's Avatar
80 4x4 Mystery Clunk in drive train SOLVED
80 4x4 Mystery Clunk in drive train SOLVED bad ring and pinion
« on: Yesterday at 04:53:01 PM »
Quote Modify Remove The previous owner put in a new engine (22r) and a new clutch and pressure plate. The tranny is original l-43. When I let out the clutch to quickly I get a clunk but it does not feel like the transmission is hitting the floor or anything like that. It feels like a really bad u joint.. He said it was alway there and he thought it was the tranny mount. When I lay under the truck and watch while someone lets the clutch out quickly I can see no movement of the transmission. The u joints are all tight. If I drive down the road and let up on the throttle ...then back down quickly... it clunks. It feels like a lot of slop somewhere. My tranny guy does not see how it could be in the tranny or t-case. He thinks mabey in the clutch assembly somewhere. We are getting ready to put in and L52 and I want to have every thing I need before hand. I hate to spend 100 bucks on a tranny mount if it is not needed.
Any one got any ideas on where this slop could be hiding.
Thanks is advance again
Mark
Old 11-18-2009, 08:00 AM
INFINITY's Avatar
check the drivers side motor mount.
Old 11-18-2009, 09:27 AM
69800's Avatar
My driveline has some play when I lay under the truck I can rotate it back and forth a fair amount.. If you were to put a mark on the rear end the play would be 3/8 to1/2 inch
motor mounts are tight
Old 11-27-2009, 05:54 PM
corteznewbie's Avatar
it could be the fourspeed its self or the rear mount and its only like20 bucks at napa or az
Old 11-27-2009, 05:59 PM
82blueyota's Avatar
my rear diff pinion bearing is going out and causing my truck to clunk when i shift. it did it on a 2wd i had about a year ago you would be amazed how mutch the pinion moves when the bearing dosent keep it in place
Old 12-04-2009, 04:15 AM
69800's Avatar
We will know on monday. I do have some axel wrap
Old 12-11-2009, 05:13 PM
69800's Avatar
The loose driveline slop was ring and pinion out of tolerence. 20 thousands.. Rebuild third member with old ring and pinion which were in great shape but put in a bearing kit and slop is gone. Mystery clunk is still there and is Axel Wrap...due to lift blocks.... New 5 speed is GREAT
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Yota.Jay
07-23-2015 08:08 PM
garagespace
07-09-2015 08:37 AM
Quick Reply: 80 4x4 Mystery Clunk in drive train
