CO2 Tire Filling Set Up w/ Suppliers
10# CO2 Tank
I found my 10# CO2 tank at my local Praxair dealer. The cost was $65 and it was a full aluminum tank in good shape (that was manufactured in 2003) and a valve and valve guard/handle. The tanks need to be hydro tested after 5 years, so the later the stamp the longer you can use the tank before testing. They sell these tanks to be exchanged for full ones at my local dealer. I did however find a local welding gas company that will fill my 10# tank while I wait for $12 plus tax. Click this link for the store locator near you. http://go.vicinity.com/praxaird/prxStart.dsp
Regulator
Then the regulator was purchased from The Source, a Cramer Decker Company. The product I ordered was the fixed 150 psi with the fixed 45degree angle and the quick disconnect (Model OA-REG150) They were great to deal with. I actually called instead of ordering online. They have a “request” form as opposed to direct ordering. It was simpler to call them at their offices and order that way. I ordered on a Friday, and received the regulator the following Monday. After filling 4 tires the assembly can get frosty but continues to pump out the CO2. They are in Irvine, CA. Here is their phone number (949)581-1300, and the link to their site. http://www.cramerdecker.com/offroadair/home.html , click on “Products” to see their goods. The prices are very competitive.
Hose
The hose was purchased locally and was the same cost as the Power Tank version from 4x4Rockshop.com. Make sure you get polyurethane hose and not nylon. Many believe that Polyurethane hose will do better in the cold temps generated by the CO2. For an online source for this hose (mine has re-usable fittings so there is no strain relief. Power Tank uses the barbed ends and has a cool molded strain relief. I could not find this any cheaper than the Power Tank version sold at 4x4Rockshop.com @ this link I then fitted the hose with the type of quick disconnects I normally use on my other air tools. http://www.4x4rockshop.com/scripts/p...idCategory=126
Inflator & Chuck
I normally use an Amflo 150 inflator with my air compressor. This inflator has the usual inline gauge that is accurate enough. I would have liked to found a quality dial type that was under $40 or so, but was unable to do so. Harbor Freight sells these for $19, and it is the only quality inflator I have seen there. I changed the chuck on it so that I could use a convenient Euro type clip on chuck from Amflo and avoid having to hold the chuck on the stem while filling. This is especially nice if the tool needs to be used while the tank might be on unstable ground. The second hand can be used to steady the tank. It is the AC18F free flowing clip on chuck. It has a strong spring and works well.
Mounting
I did not want to permanently mount the tank to the inside of my 4Runner. When wheeling, I carry a 24 Gallon Rubbermaid Action Packer with various recovery gear and tools. I love the Action Packer because of it’s sturdiness, size and ease of cargo area tie down. The CO2 System fits perfectly in the bottom of this tub. I cover it with a folded tarp for added protection from all the other gear in the Action Packer.
Cost includes shipping for non local items.
Tank $65
Regulator $38
Hose $25
Chuck $6
Quick Connects $6
Total: $134
Comparable systems run up to $300 before shipping.
I believe this system is of very high quality and of the best materials. If you do not need a variable regulator, I challenge you to find a better system. It works very well and is very cost efficient. Let me know what you think…
10# CO2 Tank
Regulator
Hose
Inflator & Chuck
Mounting
Tank $65
Regulator $38
Hose $25
Chuck $6
Quick Connects $6
Total: $134
Nice write up!
I got my system through them too. They said they would be coming out with all kinds of cool stuff soon. Call and ask for Vanessa, tell her James sent you and maybe I can get a freebie one day!
justdifferentials
14
Jun 11, 2017 08:36 PM
Diggertoy
119
Mar 5, 2005 07:00 PM
