What to do on a recent purchased 91 4runner
Okay I just got this 91 4runner V6 3VZE manual about two weeks ago. With the help of a buddy I have done some work on it already.
Replaced:
1)some small fuses
2)alternator
3)used power steering pump (still leaking)
4)replaced tail gate (some wiring issues still)
5) tires (32x11.5x15)
6) battery terminals, one ground to body one to engine block, larger gauge to fuse box that sits right next to battery
Have parts for:
1)re manufactured power steering pump
2)valve cover gasket
3)plenium gasket (just know i need it with the valve gasket)
4)oil filter and oil
5) Fan bracket pulley w/pulley (comes in tomorrow, old one stopped spinnign yesterday)
Thinking about:
1) Spark plugs and wires
2) cleaning the outside of engine to see visible leaks
Known messed up or not working pieces:
1) rear window not working
2)tailpipe/from cat on back is holy
3) windshield washer fluid not coming out
Runs sluggish up hills, fine on flat. Took it wheeling the other day and i was surprised at the abiliity on stock heigth(somewhat new to wheeling). Pulley stopped working on the way back.
Also, the stick seems to have alot of play all the way around. First stick owned but I drove my buddies the other day and it didnt move around nearly as much.
What else should I do?
Replaced:
1)some small fuses
2)alternator
Have parts for:
Thinking about:
you could really open a tin of worms with a question like that. You could just leave it alone now, or you can do a million things to it. I put a v8 in mine and things just didn't stop after that, in fact the list just keeps growing. My little 4 Runner is on its 3rd rebuild mow.
Mods are for after its running good lol. Minus a couple little things here and there. Mainly looking for service work that i need to check though.
Check the cat and 02 them are both big factor's in the power and fuel mileage department , check compression on all cylinders see if you are going to need a set of head gaskets
plugs and wires should be factory 3.0 don't work well with other then Toyota plugs and wires most of the time, rotor and cap, replace the fuel filter
run Sea foam through the motor to clean up the carbon build up on the valve train and pour some in the fuel tank to clean the injectors ,
timing belt, water pump and tensioners as a just so you know they have been done safety measure
um kinda that will help but that one is for the transfer case
this is the seat (the blue is for transfer case)
http://www.marlincrawler.com/transmi...-shifter-seats
And this is the bushing i was talking about (watch the video on the bottom)
http://www.marlincrawler.com/transmi...shifter-socket
if u replace both it will fix that problem
Jun 1, 2021 01:51 PM
Road Bull
Oct 10, 2015 04:55 PM
