oil pressure at idle
Old Oct 30, 2009 | 01:33 PM
85triz's Avatar
After warming my truck up this morning, I noticed the oil pressure seemed quite low at idle. I've got the factory oil pressure gauge infront of the shifter on my '83. When the engine was warming up, before the thermostat opened it was in the middle of the gauge, the choke was off. After the temp gauge reached halfway, I looked at the oil pressure gauge and found it seemed quite low, but havent owned the truck long enough to know how low is normal. I snapped a picture on my phone, so if anyone can clarify, is this too low? the gauge seems to work fine, like the pressure raises right up at higher rpms, it just seems quite low at idle.
Old Oct 30, 2009 | 05:03 PM
yoterr's Avatar
well if you get urself a mechanical guage idle psi is supposed to be around 4 psi, and jump to 50-60? psi at 3K so if your truck was cold it would be idled up making the oil pressure higher than it is at idle
Old Oct 30, 2009 | 07:45 PM
ajoebob's Avatar
its just a toyota thing. mine dose the same thing so i put a new oil pump on it and its still the same.
Old Oct 30, 2009 | 08:20 PM
Adam F's Avatar
Yea, its gonna be low at idle. Like yoterr said, on the cold start the engine was at high idle so the pressure was higher.
Old Oct 30, 2009 | 09:19 PM
Built2Grind's Avatar
mine had a bad sending unit, it would start out fine and slowly go wayyyyyy too low. i got really worried about it and got a mechanical gauge. everything was fine mechanically. 1 new sending unit and TA DA problem solved
Old Oct 31, 2009 | 04:13 PM
85triz's Avatar
Thanks guys, thats the answer I was hoping for
Old Nov 2, 2009 | 05:20 AM
83's Avatar
83
Here's mine, but it's a rebuilt engine..
Old Nov 2, 2009 | 10:19 AM
85triz's Avatar
is that fully warmed up, after the thermostat pops? thats about where mine was at an idle before it fully warmed up. i had kicked the high idle down and the choke was off, the engine just wasnt completely warm yet. then after it was fully warmed up it slid off to what you see in my pic.
Old Nov 2, 2009 | 10:35 AM
toyota4x4907's Avatar
Hm. Mayhaps thats whats wrong with my 22re pressure....or..it could be the main bearings since I get a slight knock on cold start sometimes ....but I have pretty much the same symptoms you describe here. It starts out fine, then after driving 15+ minutes constantly, it goes down to ALMOST the low level. and it usually stays there, even if I hit 4K rpm. it usually moves higher by about a needle width when I let off the gas ...then goes down again.
Old Nov 2, 2009 | 01:15 PM
83's Avatar
83
Don't remember...I'll look later today if I remember. Seems like you're ok, though.
Old Nov 3, 2009 | 01:36 PM
83's Avatar
83
I feel like when my truck is really warmed up (like after some time on the highway), at idle, it goes a bit lower, but just now, after getting heat in my cab, and sitting at idle, the needle was right at the first line. So just a bit lower than in my photo, but not much. Like I said, though, rebuilt engine.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Eggslinger
Jun 8, 2019 03:32 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
