22re stops making power at 3000RPMs
Old Oct 22, 2009 | 07:41 PM
strykersd's Avatar
My 4runner has never ran right, it used to misfire at idle and not make power above 3000RPMs. I found out that 2 of my exhaust valve springs were shot. Instead of fixing that engine I got a deal on a LC Engineering 22re. After swapping in the LC Engineering engine my truck stopped misfiring and passed smog, but it still doesn't make power above 3000RPMs. I'm guess it's a fuel issue, but I don't know. I recently had my injectors rebuilt through Witchhunter Performance and replaced the fuel filter. I don't think it's the fuel pressure regulator because the vacuum line going to the FPR is dry and I hear when those fail fuel shoots up into that hose. Anyone else have any ideas? Thanks
Old Oct 22, 2009 | 07:45 PM
olharleyman's Avatar
fuel pump?
Old Oct 22, 2009 | 08:07 PM
rdrttoy's Avatar
how much power is the new 22re rated for. if you get one of the higher performance engines the fuel pump wont keep up with it at higher rpms. also try to see if you ecu is givving off any error codes. The basic gasoline engine needs .5 pounds of fuel per horsepower hour. I hope this helps you.
Old Oct 22, 2009 | 08:20 PM
strykersd's Avatar
Originally Posted by olharleyman
fuel pump?
Yeah I was thinking it might be the fuel pump, but after searching the forums it seems like the fuel pumps on 22re's are hit or miss, either works or doesn't. Is there any way to check them?
I doubt it, it had the issue with the stock 22re also
Old Oct 22, 2009 | 09:14 PM
milehigheric's Avatar
Start by looking for a diagnostic code, see if it is the computer restricting revs, most ECU's will have a limp home mode which could be your case. If there is no probs with the ECU, check your fuel and air filters? Assuming it is an in tank EFI pump pull it out and check the strainer for blockage. It can only be fuel or air really.
Old Oct 22, 2009 | 09:52 PM
874runnersr5's Avatar
maybe the afm has some deadspots?
Old Oct 23, 2009 | 01:14 AM
strykersd's Avatar
Sorry forgot to mention that, no CEL. Yeah I agree with the fuel or air diagnosis, I was just pretty sure it's not air since I just cleaned out the throttle body and intake manifold, and changed all the gaskets in the process.
AFMs can have deadspots? If so, I have an extra. I'll throw that in and see what it does. If that doesn't work I'll drop the tank and check out the strainer.
Thanks for the help so far guys!
Old Oct 23, 2009 | 01:52 AM
Ya know I don't know why I didn't think to add this earlier duh, check your cat lately? a clogged cat will restrict your power majorly.
Old Oct 23, 2009 | 02:01 AM
Yeah they can, they are more common at lower revs however. If you have another try that, or test the one installed with a multimeter. The FSM should have the proper procedure but bassicly you are just looking for a continous voltage increase as the vane opens without drop-outs. They can usualy be fixed by spraying some contact cleaner. Could very well be your problem...
This is why I love aftermarket ECU's haha...A quick look at a laptop screen and you know what all your sensors are doing, makes it easy to spot abnormalities.
Old Oct 23, 2009 | 04:25 AM
Kiroshu's Avatar
gut your cat for start unless emissions are a serious issue where ur at or you can get a new one... ur choice thats one thing i'm pretty nice about not being OEM. TunE-up? If you do not have NGK or OEM plugs in it this could be ur reason. OEM plug wires are highly required otherwise ur performance will vary. Hows ur coil? Distributor cap and button? Try cleaning your flapper door in ur airflow meter. Air filter? Timing? Idle set prop? Valves adjust properly when hot?
Old Oct 23, 2009 | 11:09 AM
Windsor's Avatar
If you can, swap the cat with an off-road pipe instead of gutting it. LC Engineering sells one, ferexample.
If you gut it and you find out it wasn't the cat that was the problem, you just ruined a perfectly good (factory?) catalytic converter.
If it is the cat that's the problem, you can figure out how to buy a new one sometime between now and your next emissions test.
Hollowed-out-cats can adversely impact power compared to an off-road pipe, something about the extra turbulence in the exhaust flow.
Old Oct 23, 2009 | 11:11 AM
Windsor's Avatar
Also, when was the last time you changed out the fuel filter?
Old Oct 28, 2009 | 06:39 PM
strykersd's Avatar
I changed both my cat and fuel filter within the last two years so those should still be alright.
I swapped in my extra MAF and FPR, but no luck fixing the problem. I'll wait till I use up what gas is left in my gas tank then proceed to drop it. Thanks for the help so far guys!
Old Oct 30, 2009 | 05:58 AM
mcm375's Avatar
This is my current problem, you may want to test your VAFM.
Old Oct 30, 2009 | 06:30 AM
abecedarian's Avatar
Did you check your ignition coil, pick-up coil in the distributor and igniter?
Old Nov 5, 2009 | 06:50 PM
strykersd's Avatar
Yeah they all checked out fine.
While doing some light offroading the other day, after climbing a soft dirt hill my 22re refused to idle. It would drop to 500RPMs, then drop to 250RPMs, surge back up to 500RPMs 2 or 3 times then die. At first I thought it was a vacuum leak but I couldn't find out. I'm planning on dropping the fuel tank this weekend or sometime next week and we'll see what I find.
Old Nov 9, 2009 | 03:33 PM
strykersd's Avatar
I think I might have found the problem. It looks like my fuel strainer disintegrated and clogged the fuel pump. I'll install a new strainer tomorrow and see what it does. I attached pictures. In the second picture you'll can see some of the strainer which clogged the port. That's about half of what came out of it.
Attached Thumbnails 22re stops making power at 3000RPMs-1109091549a.jpg   22re stops making power at 3000RPMs-1109091549c.jpg
icentropy
Jul 11, 2015 07:21 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
bryan34w
Jul 6, 2015 05:53 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
