Pictures of camber adjust bolts 91 pickup? Anyone
According to Alldata, the 2wd uses shims.
"CASTER & CAMBER
2WD
Caster and camber are adjusted by increasing or decreasing the number of shims between upper arm shaft and frame mounting surface. The thickness difference between front and rear shim packs should not exceed .16 inch (4mm)."
The 4wd trucks and 4runners use adjusting cams mounted in the control arms.
"CASTER & CAMBER
2WD
I took it to the shop and they said they couldn't do it, I think I fixed it I just had tbs so cranked and I tuned them down a bit so I get a little rub but not much and tires r strait
truckmike26
Jul 24, 2024 10:24 AM
Regency
20
Jan 3, 2020 07:43 PM
