Mirror siding stuff removal...
Ah man, sorry, that sucks. I'm in the process of fixing the damage on my body from similar aftermarket panels. The previous owner pop riveted diamond plating on the side of my truck. The truck started to rust in between the panels as a result of trapping moisture, rocks, etc.
Here's what the truck looked like before I removed that junk:
And afterwards:
It was worth it to remove the plating even though I'm having to fill those holes with bondo hair (mixed with fiberglass). I hope your panels are only stuck on with tape!! As for the pinstripe, you can almost always use a heat gun and heat up the surface of the stripe, then slowly peel it off when it's a little bit warm. Then use some goo-gone to wipe up the residual residue. If that fails, use a plastic scraper (so it won't damage your paint) and remove what's left.
And afterwards:
Ended up using a scraper and paint thinner on the adhesive only. Didnt hurt a thing but was a lot of work. Also got rid of the pin stripe. You can still kinda see where the panels were. I like it a lot more this way.
If you would have just put it in a field for around 6 years it would have started coming off all on it's own, part of the driver side on my 4runner came off that way so I'm sure it would have worked for you
From: Downtown Heckronto, Ontario, Soviet Canuckistan
At least you had it easy, my truck is covered in ugly blue house paint, my avatar picture makes it look 100x better than it really is. I am terrified of the day I strip it off and repaint.
Yeah, I guess you get what you pay for, at least my engine runs great despite some rather lax maintenance and the frame isn't rusted out, which is surprising for Canada.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Regency
20
Jan 3, 2020 07:43 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
terminator
Jul 27, 2015 07:13 PM
