clutch peddle grabbing inconsistantly
Old Oct 3, 2009 | 06:54 PM
tonkatruck89's Avatar
Angry clutch peddle grabbing inconsistantly
this has happening for a little while then went away completely for a while, but now recently its happening again its a bit worse this time. when go to press the clutch in it feels soft and then when i go to let it out to start moving it grabs very very low. sometimes it grabs ON the floor with the peddle fully pressed. i have to literally RIP it out of gear if i have the clutch in and still stays engaged. if i pump it it gets a little better then grabs in a completely new spot. its almost like every time i push it in it grabs in a new spot. but then it grabs normal sometimes so i have no idea. i replaced the slave cylinder and bled the line and put new fluid in it. i think i may have to replace my clutch master cylinder? buutttt im not sure really whats causing it. there are no leaks and havent needed to add any fluid at all. any info would be greatly appreciated thanks in advance.
Old Oct 3, 2009 | 07:23 PM
BigBluePile's Avatar
Well, it's a pretty simple system. How's it work with the new slave and fluid?
Old Oct 3, 2009 | 07:28 PM
myyota's Avatar
I would replace the clutch master cylinder and the slave cylinder, it sounds like one or the other is going bad, and those parts don`t cost that much, and from what ive read on here its a good idea to replace both at the same time.
Old Oct 3, 2009 | 07:29 PM
well to be honest completely the same. it was weird in early august i drove 650 miles down to where i currently reside in kentucky from PA and it stopped doing it.. then just about 4 to 5 days ago id say it started doing it again.
Old Oct 3, 2009 | 07:33 PM
yeahh im probably going to replace the master cylinder one of the days i have off from work. seeing as i replaced the slave cylinder already i can pretty much rule that one out id say.
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Cycles
Sep 29, 2015 06:37 AM
