Anybody use POR15 for rock chips?
Old Oct 2, 2009 | 01:15 PM
Mason Dixon's Avatar
I've got a bunch of rock chips in my front bumper, hood, quarter panels that have a slight hazing of rust in them, can I sand the rust out and dab some POR15 on? Has anyone done this? Also, does it require a uv topcoat?
Old Oct 2, 2009 | 02:05 PM
DMONEY's Avatar
Yes, you can sand it out and put the POR15 right on the metal BUT if it is going to be exposed to sunlight you must topcoat it or the UV rays will denature the paint. Stuff is rock solid once you do though. Just make sure to clean and degrease the area thoroughly first or it could effect the POR15.
Old Oct 2, 2009 | 03:23 PM
bain's Avatar
Yup...what DMONEY said..and you can actually put it right on the rust without sanding..its that good...
Old Oct 2, 2009 | 04:06 PM
pattycakes77's Avatar
i've taken my dremel and a small grinding bit and ground all the rust out of the rock chip, cleaned, and dabbed POR 15 into the hole. i waited a couple days for it to cure fully and then level sanded smooth and buffed, no problems since i did it 2 years ago.
JookUpVandetti
Sep 30, 2015 08:58 AM
Phantez
Sep 30, 2015 08:24 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
