Sponsored by: CARiD
1987 Toyota stalls
Old Sep 17, 2009 | 09:59 PM
1lowyota.'s Avatar
1987 Toyota stalls
i just picked up an 87 4wd yota and it starts and runs good untill it warms up to op temp and then stalls i wired the choke open and still does it what could the prob be? also what is the reed valve and what does it do? also what is the stock height on the truck i want to find out how hight the guy before me lifted it. thanks in adavance guys
Old Sep 18, 2009 | 12:22 PM
1lowyota.'s Avatar
anyone?
Old Sep 18, 2009 | 12:33 PM
Lumpy's Avatar
Sorry man, I have not messed with a carb in a long time. Hold it...I though 87 would be EFI?
Put some pictures up of the truck and of some of the suspension. How long are the rear shackles? Are there blocks in there.
Old Sep 18, 2009 | 07:45 PM
1lowyota.'s Avatar
Old Sep 18, 2009 | 08:15 PM
RMP8080's Avatar
It could be the fuel pump, after the motor warms up you are getting vapor lock.
It could be the coil, check for spark after it stalls.
It could be the fuel filter.
Check your vacuum line for holes or broken lines.
Problem is that it could be a lot of things. Start with what I give you to check. Start with the simple things.
Old Sep 18, 2009 | 09:02 PM
1lowyota.'s Avatar
just changed the pump it starts and runs amazing then stalls when warm stays running when on the gas tho also runs rough for a min and a half before stalls but ill check the lines tomorrow o there is a line going to the red valve???? and its not hooked up but its plugged with a skew idk what the reed valve does also i might be picking up an 89 pick up im thinking about just swapping the heads for the efi so i don't have to deal with this any opinions?
Old Sep 18, 2009 | 09:23 PM
RMP8080's Avatar
change the fuel filter?
Old Sep 19, 2009 | 01:03 AM
annoyingrob's Avatar
You're just going to add more problems with EFI
Old Sep 20, 2009 | 08:08 PM
1lowyota.'s Avatar
ok well i picked up a fuel filter and a can of carb and choke cleaner ill put the filter in one day this week and ill spray the vac lines while its running to see if there is any leaks ill let you guys know what happens until then im still stumped
Old Sep 21, 2009 | 10:24 PM
1lowyota.'s Avatar
ok well i changed the fuel filter and still nothing also checked vac lines same there but i did find something interesting the fuel filter was nasty so we cut it open and it was all brown and junk but when i syphened it out of the tank the other day cuz i needed gas to get to work lol it was the norm wawa gas color but any way i also noticed that the ethanol was gelling up in the filter a little bit so i think im staying away from using that crap gas again im just guna run shell in it for now so i think that the gas gummed up the jets? in the carb. can anyone tell me the easiest way to remove the carb i was lookin at it and it looks like a pain in the ass to get off.
Old Sep 21, 2009 | 10:28 PM
toyota4x4907's Avatar
'86+ 4runners were standard with EFI. 4x4 trucks had carbs standard (efi upgrade) until '88. 2wd had carb option until '92, and both 4x4 and 2wd could be special ordered with carbs after that.
Old Sep 22, 2009 | 12:47 AM
RMP8080's Avatar
I had a problem with old gas in the tank, also rust. Had to remove the fuel tank and drain and clean. it had alot of rust.
Also had to replace the fuel pickup tube.
Old Sep 22, 2009 | 12:49 AM
RMP8080's Avatar
Also rebuild carb kits are around 20 - 30 dollars
Old Sep 22, 2009 | 05:01 AM
Lumpy's Avatar
Gotcha thank you...No matter how hard I try, I'll probably forget again though.
Old Sep 22, 2009 | 09:02 AM
1lowyota.'s Avatar
i think the filter was never changed before but here is a pic of what it looked like
Old Sep 22, 2009 | 08:39 PM
RMP8080's Avatar
Problem
Old Sep 23, 2009 | 05:42 PM
1lowyota.'s Avatar
yup time for a carb rebuild is there any wright ups on removal and rebuild?
Old Sep 30, 2009 | 05:30 PM
1lowyota.'s Avatar
ok the other day i sprayed a bunch of carb cleaner in the carb and let it sit for a bit and messed around with the choke and drop down it didnt stay running that day but when i moved it out of the driveway last night i left it running and when it hit op temp it stayed running for a while i then gave it gas and when i let off it stalled but i started it up and cracked it open a few times and then it held an idle again o and i filled the tank with the shell gas now no more wawa gas! im thinking the ethanol in the wawa gas messed with the carb and now its starting to clean out.
Old Sep 30, 2009 | 05:40 PM
Lumpy's Avatar
That could be...SeaFoam it might help out as well.
I don't think carb's will like the mix in the fuel, can't compensate for the difference in burning.
Old Oct 4, 2009 | 10:35 AM
master tech1's Avatar
in the simplest way i can say u need more then a rebuid kit u need a new carb
