4Runner running rough.
Old Sep 2, 2009 | 09:02 AM
B. Graves's Avatar
Hi, my dad has a 1990 2-door 4Runner, 3.0, Auto, 4X4. I runs really rough when you first crank it up and drive for a while and it gets better as you go but not perfect. It stutters and misses really bad. It doesnt do it all the time though. It does most of the time but not all the time. He took it to a very good reputable shop and it wouldnt do it while it was there. He said bring it back when it does it again but you cant predict when it does it. It doesnt throw a CEL. Any ideas?
Old Sep 2, 2009 | 09:06 AM
BoostinChick's Avatar
Test for vacuum leaks? When was the last tune up done?
Old Sep 2, 2009 | 09:11 AM
B. Graves's Avatar
how can you test for vacuum leaks? is there any special procedure or tools you need?
Old Sep 2, 2009 | 05:47 PM
B. Graves's Avatar
anyone else?
Old Sep 2, 2009 | 05:59 PM
Levis Pennae's Avatar
You can do a basic test for vacuum leaks by spraying a liquid (WD-40, water, pee...) and seeing where it bubbles.
Old Sep 2, 2009 | 06:21 PM
B. Graves's Avatar
would a vacuum leak be off and on though?
Old Sep 4, 2009 | 05:23 AM
Depending on where the leak is yes. Going from Park to Drive pulls vacuum.
Old Sep 27, 2009 | 04:51 PM
B. Graves's Avatar
well, weve studied ans discovered that it only does it when the humidity is high or if its rainy out. all the other times its fine.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
DacodaYota
Sep 2, 2015 02:13 PM
88Toy
Jul 4, 2015 02:11 PM
CJ94yota
Jul 3, 2015 10:14 PM
