92 4 runner ac amp diagram
so like the title says I am in need of a ac amplifer diagram so I can wire it up for my swapped in 22re (used to be 3rz). I have checked alldata but found nothin. Thank in advance for the help!
Jason
Jason
bump for info!
I found a wiring diagram. I tied in the igniter signal but still no go. I pulled a vac and charged the system with the compressor hot wired. i am thinking may need a 4 cyl amplifier. I searched for quite a while looking for an answer but nothing solid. I guess it would be possible to wire in a stand alone fashion simply using relays tied to the pressure switch to control the cycles and the idle up.
either way let me know what you guys think
jason
jason
Jnkml
Jul 6, 2015 01:20 PM
