Pre 84 Trucks 1st gen pickups
22r/20r Hybrid detailed info
Old Aug 7, 2009 | 07:29 AM
inertia's Avatar
Just curious if any one has a link to a tech write up on the 20r/22r hybrid. I currently just built one with .040 pistons, rv cam, stainless valves over sized springs, which will include a 38 weber carb. The motor is put together in the truck and now I would like to find out more about which vacuum and water lines are needed and were they need to go. What I can eliminate, and what the timing needs to be set at. Also any other ideas or tech info would be much appriciated, thanks.
Old Aug 11, 2009 | 09:32 AM
brooklee1000's Avatar
Check lcengineering website for timing info, and other info you might need.
Old Aug 11, 2009 | 09:36 AM
check LCengineering website. Lots of info there for timing and other.
TheBFA
Feb 15, 2020 06:55 AM
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
buckz6319
Aug 5, 2017 03:50 AM
White Stripe
Oct 6, 2015 10:47 AM
toyotasaurus
Sep 24, 2015 03:30 PM
