Starter Leaking Green Stuff?
I noticed my starter was making a grinding noise today like it was staying engaged too long. When I went to look at it I noticed that the starter was leaking this green stuff. Its not antifreeze. The starter is brand new and the first time it was used is today. Has anyone seen this before or know what this stuff is?
That looks weird... it may be the lube they used rebuilding it reacted in a bad way with the copper wires inside or something... either that or it got contaminated inside somehow... really strange in any case... I'd go back to the shop and get them to look at it if I were you...
I think it's just some sort of water resistant grease but I'd ask the shop just to be sure. Many moons ago I used a green grease on the bearings and crank on my "take 5 bikes and make 1" BMX style bike. But it was not quite that green.
iv never seen anything like that before
and matt LOL, although might wanna be carefully someone might actually be stupid enough to spray starting fluid in there starter (starting fluid electrical contacts would be an bad mix)
Thanks for the help everyone, I'm taking the starter back and I'm going to switch it out for one that doesnt leak this green stuff. I checked the starter fluid and its full I even checked the turn signal fluid and the muffler bearing even the kanuter valve all are in working order, HaHa
The noise is probably caused by bendix drive mechanism, though that's a pretty uncommon fault on Denso (OEM) starters. I'd take it apart and see if anything looks broken. Or buy a new one, if you don't have time. They're not too tough to take apart. I'd replace the contacts while you're at it.
The green stuff is just grease, why its oozing out, I'm not sure. Again, I'd take it apart.
Bendix
http://www.indiacar.com/infobank/battery1_od.htm
polo451
13
Nov 20, 2016 07:49 PM
ZONAYODA
Jul 13, 2015 07:17 PM
