fuel inj. onto carb motor
Old Aug 1, 2009 | 10:17 AM
fireman7472's Avatar
I was wondering how hard is it to swap a stock fuel inj unit over to a carb. motor? also if anyone could tell me a good place to find repair mauals for a first gen 4-runner? btw, I have an 88 runner (inj), 88 truck (carb), and am looking at getting an 86 runner. both of the runners have bad engines and the truck runs great, I am wanting to build one or two good motors out of all 3 of them. If anyone has some insight on this it would be greatly appreciated. thanks
Old Aug 1, 2009 | 10:28 AM
korn111685's Avatar
well sounds like you have everything you need.. get to swaping..
should'nt be to hard.. strip the 22r of it's intake and brakets, pullies and all.. exhaust should be the same?? use everything off the 22re, intake, wireing, computer, emissions, pullies, brakets, fuel tank, and so on.. list is long but do it in steps and it'll turn out fine. lable things so you dont forget.
the heads are the same other then the cam for the 22r has a lobe to run the manual fuel pump which wont matter much.. just use the block off plate from the efi head.
i've been looking into this for a while. just have not found myself a cheap full efi doner yet.
Old Aug 1, 2009 | 12:02 PM
93YotaMonster's Avatar
some one please correct me if im wrong, inset the intake manifold different. it want bolt up to the 22r head.
Old Aug 1, 2009 | 08:22 PM
adams707's Avatar
it should bolt up perfect from 1984 and newer
Old Aug 1, 2009 | 09:58 PM
Robert m's Avatar
wait, am i reading this wrong or do you want to swap from EFI to a carb setup? if so why go backwards in technology?
skoti89
Sep 11, 2015 07:46 AM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
karbin
Jul 5, 2015 11:37 PM
