More rearend woes....
Old Jul 29, 2009 | 06:53 PM
aadown1214's Avatar
Thank yall who offered advice on how to get my rearend to quit leaking. I checked my axle vent and it was indeed clogged. I then took the truck on a decently long drive that would allow the axle to build up some pressure and leak.......got home, and it still is leaking but not as much. I tried to loosen the pinion nut, and its been torqued down so much that I can't break it free without an impact. Does anyone know what the factory spec torque should be on the pinion nut? The reason I ask is that I think that the seal is maybe crushed, and it smells like burnt rubber. Any thoughts?
Old Jul 29, 2009 | 08:34 PM
4Crawler's Avatar
I usually use about 90 ft-lb on mine:
- http://www.4crawler.com/4x4/CheapTri...ionSeal/8.html
Upwards of 135 ft-lb is what is used to crush the crush sleeve when setting up the pinion bearing, so you don't want to go too high.
tylerh11
Feb 4, 2008 05:18 PM
Shoorty911
14
Jul 12, 2003 10:34 PM
Dashunde
16
Jan 28, 2003 07:18 PM
