Brake pins.....
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Brake pins.....
I'm in the middle of installing new front drive axles, bearings, and my Aisin hubs. Already got the driver's side done, and put back 2gether. I've started the passenger side, and noticed that I only had 1 brake pad retainer pin. Can I buy 1 at Vatozone or Napa? Kinda hoping I don't have to go to the stealership.
The pin I'm referring to, goes thru the caliper, and holds the pad in place.
Thanks all
Thanks all
You could probably just make one for cheap- they just locate the pads while the calipers aren't squeezing.
BUT... they probably aren't too expensive at the stealership. The part number is 477488. http://www.toyodiy.com/parts/p_U_199...MSEA_4705.html
Unless you're good at fabrication, I'd be leary of making my own. What if the pad doesn't slide correctly 'cause the pin isn't straight, or the right diameter (binds up)? I'd take Matt up on his offer. I don't mess with brakes...
I just went thorough this too. My local advance didin't have them, nor do they have them available to order. Autozone does carry them, $8:
Part number: H15045
http://www.autozone.com/autozone/cat...entId=cat30058
Jason
Part number: H15045
Jason
1uzRunner
63
Nov 10, 2018 03:58 PM
