Trouble with my oil pressure switch.
Old Jul 8, 2009 | 09:40 PM
JeffreyJones's Avatar
Unhappy Trouble with my oil pressure switch.
I have a 1994 Toyota 4x4 extended cab with the 22-re engine. My oil pressure guage was all over the place and I was told I should replace the switch. I went to Autozone and got a replacement but it isn't the same as what's in there. At least I don't think it is the same. The new one is pretty small. The thing I think it replaces is much bigger and has a brass housing around it. The threads where it attaches to the block look the same and the clip will attach to it. Are aftermarket replacements smaller or did I just get the wrong part. I am rebuilding a rebuild from he77 and I could sure use some help before something else goes wrong.
Thanks in advance,
Jeff
Old Jul 8, 2009 | 09:48 PM
854x4's Avatar
There are two different oil pressure senders for the 22re one is for a gauge and one is for a light. Dont plug in the sender and turn the truck on untill you are sure you have the right one or you could fry your gauge. Post a picture of the two if you can.
Old Jul 8, 2009 | 10:10 PM
pictures
here are the pics of what I have and what I think needs to be replaced.
Attached Thumbnails Trouble with my oil pressure switch.-new-one.jpg   Trouble with my oil pressure switch.-old-one.jpg
Old Jul 8, 2009 | 10:14 PM
BigBluePile's Avatar
Welcome to Yotatech Jeff!!!
There is two different senders for the 22R-E. If you have the SR5 cluster which has an actually gauge for oil pressure and a tach then you'll need the "bell" shaped sender. The regular gauge cluster which just has an oil light is a smaller unit.
SR5 Guage switch:
Standard Guage Light Switch:
Anything else you need, please utilize the search feature and a lot of your answers will be found there!
Old Jul 8, 2009 | 10:16 PM
854x4's Avatar
The first picture looks like its for an oil light and the second picture looks like one that goes to a gauge. I think autozone sold you the wrong one. Could you post the part number?
Old Jul 8, 2009 | 10:29 PM
Smile
I'm not sure what the part number is and my truck is at a different house. I'll try to get it and post it tomorrow. Thanks.
Old Jul 8, 2009 | 11:03 PM
The part number on the box is PS325 it is a Duralast part.
Old Jul 8, 2009 | 11:09 PM
854x4's Avatar
Acording to autozones website and the part number that part is for a oil light and not an oil gauge. Looks like you will have to take that part back and get one that is meant for a gauge.
Old Jul 8, 2009 | 11:11 PM
854x4's Avatar
On their website it shows that part # OP26201 made by neihoff is the correct one for a gauge setup but theres no picture so dont hold me to that.
Old Jul 9, 2009 | 03:03 AM
jason191918's Avatar
Install a mechanical oil pressure gauge. Better than both.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
