driveshaft parts swap question
Old Jun 28, 2009 | 05:40 PM
octane99's Avatar
Lightbulb driveshaft parts swap question
I have a 1985 4runner> I just gave it a 5 inch lift. When I did this I suspect that it made a little too much of an angle for the driveshaft because when I step on the gas the truck viberates and you hear a thumping noise (u Joints). I have a couple extera front shafts that have the double U jount assembely. I was just wondering it it would be a good idea to use one of the double U joint assembilies from the front driveshafts on the rear driveshaft? Could the assembily handle it and if not recomended I need some help getting steered in the right direction. Please help, thank you
Old Jun 28, 2009 | 05:51 PM
waskillywabbit's Avatar
Classic u-joint symptoms with the stepping on the gas.
Front or rear drive shaft? Both?
I always put a double cardan on my rear d-shaft once I lift one...but that is just me. Did you lengthen your drive shafts properly?
U-joints are your thump for sure.
Old Jun 28, 2009 | 06:00 PM
octane99's Avatar
thanks
Thank you very much I think you answered my question
the rear shaft is the one having the problem
I am getting it sent in to be lengenthened in a week but I though that wouldnt be a problem untile I put the suspension to the test.
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
