Rear domelight doesn't turn on anymore when opening rear gate/hatch?
Old Jun 25, 2009 | 10:06 AM
Jason B's Avatar
All of a sudden when I open the rear gate, the rear domelight doesn't come on anymore. It's set to "door" on the switch. If I move it to "on" it comes on, so it's not the bulb. Any ideas? Since it doesn't come on, the factory alarm won't sound either when the gate is opened. I'm assuming because it's not getting a signal that the door is open.
Old Jun 25, 2009 | 10:16 AM
Elton's Avatar
darn jason whats goin on with your truck if its not one thing its something else have u checked the door pin ?
Old Jun 25, 2009 | 10:19 AM
Jason B's Avatar
I don't think there is a PIN for the rear gate???
Old Jun 25, 2009 | 10:23 AM
Elton's Avatar
there should be otherwise how does it no its open
Old Jun 25, 2009 | 11:04 AM
Jason B's Avatar
It's built inside the latch that in the gate. I'm going to take that latch apart and see if something is stuck.
Old Jun 25, 2009 | 11:10 AM
spokane.yota.man's Avatar
my 98 has the same problem. i believe the light switch mechanism is inside the latch and i was told by parts department that you have to replace the entire unit. it was a few hundred from the dealer so i am thinking find it used or not worry about it. let me know if you are able to fix it.
Old Jun 25, 2009 | 11:28 AM
Jason B's Avatar
Ok, just took the 3 bolts out and pulled off the rubber boot on the back side of the latch, then removed the tention wire that is clipped into it to have more room. I jiggled it around and cleaned it out as much as I could with a rag and mineral spirits around all the dirty parts I could see. Now it works again! I think it just got dirty or something got stuck. I bet you can get it to work again.
Old Jun 25, 2009 | 02:27 PM
Mtn Mike's Avatar
My 2000 has the exact same problem. Thanks for posting the fix!
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Steezy96yota
Jul 6, 2015 10:00 AM
karbin
Jul 5, 2015 11:37 PM
