Sponsored by: CARiD
how do you tie your toy down?
Old Jun 19, 2009 | 12:36 AM
ajoebob's Avatar
i normaly trailer my toyota when i go anywhere and woundered how you all chain down your trucks.
i take a chain over the frame in back and use a braker to pull it tight then do the same to the frount.it stays tight and wount buge when i pull it.
Old Jun 19, 2009 | 12:37 AM
CRafferty's Avatar
I have a 20' All Purpose trailer that we use for my 4R and our Willy's. What do you tow it with?
Old Jun 19, 2009 | 02:44 AM
dropzone's Avatar
Fossilized
I was told not to tie down a car/truck to the frame (did it for years) but rather go over the axles. Found a set of 4 ratchet tie downs on ebay fairly reasonable, used them for awhile now and work great..I still carry a set of chains and binders just in case some low life slices a strap...
the wear straps where they contact the axle have not shown any wear after being used 8-10x's nice thing is that they can be easily replaced with old fire hose if need be.
Old Jun 19, 2009 | 05:38 AM
85toySuperLift's Avatar
yea, i dont see why you couldnt go with chains along the axels.. my buddy has a 9000lb winch on the front and a 2000lb on the back of his flat deck on his trick, and he has two heavy tow hooks on the front and back of his truck. he winchs his down a bit, and throws a heavy strap like ocd has over the flat deck.
Old Jun 19, 2009 | 07:03 AM
wheatus's Avatar
i chain over the axles because they are under the suspension and do not move. i always use chains and binders.
Old Jun 19, 2009 | 07:21 AM
algranger's Avatar
On the axles kinda like that ^^
Old Jun 19, 2009 | 07:30 AM
UKMyers's Avatar
I got a set of tie downs specifically for doing a vehicle after having a near disaster with some cheap walmart 5K straps. The kit I now have has loops that are padded and go around the axles then you hook a 10K ratchet strap to that. I have them going off in a V to get some lateral restraint. In addition I put a strap through both corners of my front tube bumper and suck the leafs down almost to the bumpstops. Finally I use one strap through the rear bumper to suck the rear down. It tows much more stable with the leafs are sucked down when there's no body roll on the rig. Tow rig is my 06 DC Tundra and trailer is a 16' dovetailed Carson.
Old Jun 19, 2009 | 07:43 AM
algranger's Avatar
Oh yeah i got some ratchet straps from my local lumber supply they were $50 a piece but i wouldnt be surprised to see them lift the front of my truck a few feet off the ground
They look similar to those ^^
Old Jun 19, 2009 | 08:29 AM
scuba's Avatar
In an article I read not too long ago, The proper way is in an X pattern..
Old Jun 19, 2009 | 03:11 PM
ajoebob's Avatar
i tow with my '97 dodge diesel. some people say go off the axles but it seems like the truck would move around alot.(not the wheels the body) when dealerships hall cars dont they tie down off the frame?
Old Jun 19, 2009 | 03:20 PM
algranger's Avatar
Not sure where the delivery drivers tie down but tying on the frame, you have your suspension in the equation where as tying to the axles, its a direct reliable pressure from the tie downs to the trailer floor.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
beltcutter
Sep 30, 2015 06:14 AM
oldblue
Sep 28, 2015 04:07 PM
