how do you tie your toy down?
i normaly trailer my toyota when i go anywhere and woundered how you all chain down your trucks.
i take a chain over the frame in back and use a braker to pull it tight then do the same to the frount.it stays tight and wount buge when i pull it.
I was told not to tie down a car/truck to the frame (did it for years) but rather go over the axles. Found a set of 4 ratchet tie downs on ebay fairly reasonable, used them for awhile now and work great..I still carry a set of chains and binders just in case some low life slices a strap...
the wear straps where they contact the axle have not shown any wear after being used 8-10x's nice thing is that they can be easily replaced with old fire hose if need be.
yea, i dont see why you couldnt go with chains along the axels.. my buddy has a 9000lb winch on the front and a 2000lb on the back of his flat deck on his trick, and he has two heavy tow hooks on the front and back of his truck. he winchs his down a bit, and throws a heavy strap like ocd has over the flat deck.
I got a set of tie downs specifically for doing a vehicle after having a near disaster with some cheap walmart 5K straps. The kit I now have has loops that are padded and go around the axles then you hook a 10K ratchet strap to that. I have them going off in a V to get some lateral restraint. In addition I put a strap through both corners of my front tube bumper and suck the leafs down almost to the bumpstops. Finally I use one strap through the rear bumper to suck the rear down. It tows much more stable with the leafs are sucked down when there's no body roll on the rig. Tow rig is my 06 DC Tundra and trailer is a 16' dovetailed Carson.
Oh yeah i got some ratchet straps from my local lumber supply they were $50 a piece but i wouldnt be surprised to see them lift the front of my truck a few feet off the ground
They look similar to those ^^
i tow with my '97 dodge diesel. some people say go off the axles but it seems like the truck would move around alot.(not the wheels the body) when dealerships hall cars dont they tie down off the frame?
Not sure where the delivery drivers tie down but tying on the frame, you have your suspension in the equation where as tying to the axles, its a direct reliable pressure from the tie downs to the trailer floor.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
