Flywheel stuck on crankshaft?? 22r
Was wondering if any one has any tip on removing flywheel that is stuck in crankshaft once 6 bolts are removed?
Replaced clutch a couple years ago and since then have dropped trans. to retighten flywheel bolts. Planning on buying new bolts and using either blue or red loctite. Primarily though I need to remove flywheel to resurface/replace to avoid this problem in the future. Any tips or tricks would be greatly appreciated.
TransAmBandit
Jul 28, 2015 11:30 PM
