rear drive shaft
rear drive shaft
on long wheel based double cardan joint rear drive shaft trucks, is this necessary? I have seen same length truck without this.....
reason for asking is I am getting vibration on slightly hard acceleration from standstill (similar to uneven flywheel) , I had it turned already, replaced the clutch assy too.
the truck is a crewcab SFA hilux diesel (NON-US), rear is lifted to about 5", custom leaves, 2" longer shackles.... has degree shims that aligned the 3rd to the tcase good enough.
I am thinking that removing the double cardan/ the center-bearing(aligned too to match the lift) that holds it will get rid of the vibes.
help?
help?
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
