Do you really need one of these lifts to go all out???
might get a 85 I want to lift it and it be a very capable SA I will re gear and lock the diffs eventually but does one really need to go with the expensive allpro or other fancy kits for a good lift with good flex???
I have heard that requires ALOT of fabrication... man my 3rd gen was way cheaper to lift than this 85 haha but after I lift this it will have 10 times as much flex haha im thinking of buying a TG bumper for it and a locker first and then saving for a lift it has 31's on it right now and smittybilt bumpers and a warn winch... Any decent priced locker suggestions???
I would look into Alcan Springs. There built to fit you truck and they flex well. My last set i bought were fronts and i got them for about three hundo for the pair.. But they have orbital eyes in em.
an id say aussie lockers are pretty cheap. my buddy got em and he loves them.
RUF = make a pack, and bolt it in the front...fab = 0
63s = Buy the Sky Maunfacturing kit, weld on the hangers, bolt up so 63s fab = 0
quick and easy way to get good cheap flex
Alot of people running the RUF and 63's in the rear??? is it comparible to a TG lift or so as far as flex??? and any good info on how to move the axle forward and how far forward???
I'll spoon feed
RUF
http://www.pirate4x4.com/forum/showthread.php?t=265669
63s
http://www.pirate4x4.com/forum/showt...threadid=20665
Waggys
WAGONEER / WAGGY SPRINGS
These are stock Jeep Wagoneer Springs
Length: 47" (Length is eye to eye)
Bushing: 3"
Lift: 3.5 - 3.75"
Cost: $200 New, $60-$100 Used
From JcWhitney.com:
1976 - 1992 Jeep Wagoneer, Front Leaf Spring
7 Heavy-duty Leaves #07ZX2048P $99.95 Ea
5 Leaves #07ZX2047B $84.95 Ea
The 7 leaf is supposed to be the ones you are looking for.
Pinion angle can be an issue if you just bolt waggs to the stock location. If you have dropped hanger or dual cases the problem is lessened.
44044 SPRINGS
44044s are Rancho Jeep Wagoneer Lift Springs.
Center Pin split (front/rear) 22.5"/24.5"
Bushing: 2 3/4" & 3"
Lift: 5.25 - 5.5" (Lift is approximate and uses 1.5" longer than stock shackles giving 3/4" of lift)
Cost: $250 (Cost is for both sides incl. shipping/give or take)
44044's do not (by themselves) move your axle forward. They are the same length on the front half as stock toys (22.5"). While they do move the axle forward because of the lift they provide (arch in spring), when they compress to the point that they are flat, it's the same. Estimated 1/2" of actual axle relocation forward.
http://bbs.off-road.com/wwwthreads_u...ith%20dims.jpg
RUF
63s
Waggys
Bushing: 3"
Lift: 3.5 - 3.75"
From JcWhitney.com:
44044 SPRINGS
I read the threads on pirate already I searched and found that on here but it only provides 3 of lift or so... are the 44044's for front or rear? and same question for the waggy's? With the waggys where would you bolt the waggy's to make the pinion angle better? My main question is do one of these suspension set ups provide good flex I want to do some crawling are the TG kits or allpro's that much better? I really wanted around 4 of lift...
Here is my setup with 63's and rears up front. I spent roughly $200 on it its super strong and pretty flexy.
No it takes a lot to flex the front out it has TONS of droop.. that was close in the first pic.
Here is before i welded the front hanger on, it sat pretty level. I just wanted a little more lift in the front so i can clear 36" tires
Is there a reason more people do the 63's in the rear than 44044's??? I was thinking RUF and 44044 out back... Also any info on the hi steer or whatever you have to do to the steering with this lift???
I've never heard of 44044's what are those?
Steering you can go with a drop arm like this one but it leaves much to be desired
I would go histeer asap. I just cant afford it yet.
I went with the 63's cause they were cheap, flexy, and can carry weight and dont give much body roll
Where can you get the histeer and install directions??? 44044 are the jeep wagoneer lift springs post above says it gives 5.25-5.5 of lift... With the RUF should I buy new Rears and how do I make the packet for certain amount of lift and where to get em??? thanks!!!
