I can't get the front IFS diff cover to come off....HELP
I'm trying to take the IFS diff cover off of an ADD v6 4.88 diff to switch axle tubes with my 4 cyl non ADD. Seems like the gasket is acting like a glue, how should I go about getting it off. I've pounded it with a rubber dead blow mallet no go, tried wedging a flat head inbetween the cover and diff and still no go. Any ideas?
I have to take the cover off in order to remove the axle tubes and half shaft. there is a clip that must be pried apart...
but I believe the front diff on IFS, the front cover portion is removable, like your average GM, Dodge, or Ford diff. only thing special about it is that it's got a mount on it that connects it to the frame via a rubber bushing
I've cut through cured gasket material like that with guitar string
wrap each end around a peice of wood, and run the wire in between the front cover and axel housing, and run it back and forth to use it kinda like a saw. even if you can only get it so go a little bit, you should then be able to get a flat-head screw-driver in there a little, then tap on it with a hammer to wedge it in and cause the two to separateyou DID get all the bolts out, right?
the 3rd member with the gears, yes, the shafts would have to be removed
I ended up grindin my big pry bar down on the edge (thank you craftsman tools
I'll just go get a new one now) and slid it threw the bushing and leveraged it off kinda so I got it off!!
It was on there tight!Thanks for the ideas though guys!
I had the front diff cover off last weekend, and it took a few minutes of tapping at the mounting boss with a plastic dead blow mallet, but it eventually came off. The only thing holding the cover on (besides the screws) is whatever sealing compound was used; RTV, FIPG, etc..., and superbleeder is correct, you do not have to remove the gear shafts.
A good size dead blow mallet will knock it off without damage, a rubber mallet will just tickle the cover.
Sorry everyone. I wasn't trying to upset anyone. I haven't worked on my buddie's 93 much, but i have removed the entire diff carrier once. I didn't pay a lot of attention to it, but I didn't remember seeing a removable cover on the front. Sorry! The way y'all described it does make sense.
Glad to hear your got the cover off!!
Good Luck with the project,
Grant
Grant
Grant
Grant
I don't think anyone was butt hurt by it
If it was a solid front axle you'd a been right
i just got mine taken apart a few days ago and that sucker was on there. ended up using a thin, rigid putty knife and a hammer and then it just pops right off - took one whack. I've still gotta check the thread i posted asking questions about swapping tubes, but how are you dealing with the oil seal?
Anyone know the part number or where I can get an oil seal for the swap? Or a link to some more indepth info on it?
Thanks for the heads up highonpottery
Here's what I use for reference:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
It's handy to have around when you can't find that last bolts holding something on.
