Not sure if i need this bolt in the middle or not on the exhaust?
Old May 7, 2009 | 04:33 PM
calltrex's Avatar
22RE Header
Not sure if i need this bolt in the middle or not??
When i took the old exh gasket off it was cut in 2 pieces. I put the new gasket on but left it in 1 piece. noticed after that i couldnt put the middle bolt in. Dont think I need it but just making sure..
was only worried if it plugged a coolant hole or something from the stock exhaust?
Last edited by waskillywabbit; May 7, 2009 at 06:12 PM. Reason: Please do not post generic titles per posted sticky
Old May 7, 2009 | 04:50 PM
malteserunner's Avatar
You don't need it. I don't have it in mine (Downey header).. Good luck!
Old May 7, 2009 | 05:42 PM
corax's Avatar
x2, you'll be fine
Old May 7, 2009 | 09:34 PM
iamsuperbleeder's Avatar
yeah, I don't think it's needed, but I once thought that I had an exhaust leak from there; oddly enough, I put a bolt in it, and the leak stopped, but came back within a day turns out the cheap paper gasket that came with the header had broken apart into about 20 peices, lol
Old May 8, 2009 | 07:19 AM
DeathCougar's Avatar
The center hole is there for othe earlier 22R which used just a center exhaust bolt, instead of two in the middle (one on each side) You do not need it.
jashoeuh
Nov 18, 2024 08:08 AM
Blamalam
Mar 12, 2022 07:34 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
accuracy
Aug 6, 2015 12:32 PM
hexrain
Jul 12, 2015 01:13 PM
